Prefab soffit insulation baffles
![](https://secure.gravatar.com/avatar/bf675920d292aec33c8ba687d952ed06?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
Is anyone aware of a prefab soffit insulation baffle that offers a 2″ chute opening? Fine Homebuilding had a recent article in which Joe Lstiburek indicated that a 2″ airspace in the vent chute should be the minimum as opposed to 1″ per code for best performance. A product from AccuVent was shown in the article, but it doesn’t achieve that 2″ opening. Are there any prefab alternatives available that do? If not, is there one that gets close? Thanks.
Milan,
Your best bet may be cardboard baffles. They are stapled to the rafters rather than the deck, which gives you the flexibility to pick any gap size you want. Available through insulation supply houses.
Thanks Torsten ... makes sense ... attach to the sides to set the gap ... in this case to 2".
