Possible to Calculate BTUs from Surface Temperature
stevedavis | Posted in General Questions on
Basic theory question. I have an IR camera. Is it possible to calculate BTU gains and losses based on surface temperature?
For example, if I have a wall that IR camera is saying is 80F. And I have a room that’s air temperature is 70F. Is it possible to calculate the conductive heat gain?
  1. walta100 | | #1
    I don’t think is as simple as you are hoping. The volume of air flowing across the wall would be a huge unknowable factor.
    DCcontrarian | | #2
    Is 80F the interior or exterior temperature of the wall?
    1. stevedavis | | #3
      In this hypothetical scenario, it would be the interior temperature of the wall.
        DCcontrarian | | #4
        The rule of thumb used for radiant heat design is that a floor delivers 2 BTU/SF for every degree in temperature difference, and a ceiling delivers 0.71. (These are from John Siegenthaler's articles).
        A wall would be somewhere in between.
  3. walta100 | | #5
    If this was electronics Ohms law calculation test question and BTUs = Watts, Temp = Volts, Air flow = Current. We only know one of the three variables it is impossible to answer because two are required before you can calculate the third.
