Polyiso question
![](https://secure.gravatar.com/avatar/8000f8d2edb1d810e66d1e17e1e04de6?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Ft.png&r=g)
Hi I’m new to this so bear with me , it’s a question on polyiso . I have 130 sheets of 1 3/4 polyiso , I’m going to use it on my exterior walls on a 14 x70 Mobile home then sheet with zip system . My question is on the roof , it’s a 4/12 and I’m using HD comp roofing with ice and snow barrier. The ceiling will be invented 2×10 . So the cavity will be 8.5 inches with rock wool filling the rafter bays . Can I put the polyiso on top of rafters before sheathing it I don’t want to sandwich it between 2 sheaths due to weight. It is mainly top help with the thermal bridging on roof . Can I do this from the inside and get the same effect. It’s a high ceiling so I wouldn’t loose head space on the inside . Is this still a effective use of the polyiso . Or might it be better used on the underside being it’s a mobile home . I’ve thought about wrapping the whole thing like my yeti cooler . I’m using the proper air and ventilation on the inside for air quality and efficiency. Thanks ken
You can't put the rigid directly over the rafters, they are not meant to handle that much contact pressure.
If you want a compact roof, with the width you are proposing, I would drop the rafters down to minimum size for span/snow load, install T&G as roof deck leaving it exposed on the inside. This saves you the weight/time of finishing interior drywall. When I've done this, I find it is quicker to pre-finish the rafters and the T&G before installing.
You roof would than be:
rafters
T&G
peel and stick air/vapor barrier
rigid
plywood
underlayment
shingles
You further save some weight by going with a metal roof over 1x4 on flat and skipping the plywood over the foam.
I’m spanning from one side to the other and it’s 15. .5 feet . So 2x10 is required on this one . I thought about t and g but I’ve got a ton of building materials like my zip sheathing and 2x10 and all this polyiso already . I don’t no if polyiso on the interior directly covering my rafters then doing Sheetrock over that would give the same break I’m wanting . It’s hanging so pressure on the polyiso would be minimal. With 8.5 inches I’m not sure if polyiso is really needed . At r5 a inch on rock wool that’s a r40 already . I’m thinking it might be better used on the under carriage of the mobile . And I’ve already saved 35 bundles of roofing also yup I’m a packrat. So my savings is great on this but I want a ultra efficient mobile when done . Polyiso would bring it to a r50 if I do it before Sheetrock .
