Polyiso insulation behind fiberglass
![](https://secure.gravatar.com/avatar/f5c278b60609223fd59f82dedf2066ec?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
Hi All,
I am remodeling a bathroom and have all the drywall off. The home is 40 years old, and 3 1/2″ foil faced fiberglass insulation was used in the walls and the ceiling. It is in good shape. I have several sheets of used, 3″ thick polyiso insulation, black paper faced (not foil). I was thinking of removing the fiberglass, then putting polyiso behind it, then replacing the fiberglass. Anyone see any problems with this (moisture, mold, etc).
thanks.
Michael,
I don't think you'll have any problems, as long as you air seal the perimeter of each piece of rigid foam, using caulk, canned spray foam, or high quality tape.
Martin,
thanks for the response. I'm looking forward to a little warmer bathroom.
