Polyethylene quality and characteristics
![](https://secure.gravatar.com/avatar/84473f5d67ba7b3cb0bc1060a245b0a9?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
Hi. I have come across various qualities of polyethylene for use under my slab. The prices vary considerably; from ~$120 to $280 for 10 mil 20’x100′. I have been told that thickness being equal, some brands will degrade in a very short period of time (matter of years), as well as off-gas significantly more. They claim that the type that is “agricultural/construction film” are cheap and not intended for under slab use. Is there truth to this, and should I shell out 65-75% more money for the “better” grade plastic? Thanks in advance.
Matthew,
As far as I know, the main reason that polyethylene degrades is UV exposure (sunlight).
Keep the polyethylene in the shade. Once it is covered with concrete, it should be fine. I have used 6 mil poly for the purpose, and I sleep well at night.
I have used boat shrink wrap which is darn good stuff just because I had some. I also laid generic black 6 mil on wet dirt in a crawlspace twenty years ago, was on it just this last month crawling about and it is like the day I installed it.
