Polyether sealants
![](https://secure.gravatar.com/avatar/385f8b3fe48a577f654bad0f5f5c2519?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fk.png&r=g)
I searched for polyether, and came up with 3 (irrelevant) results on gba, and they also were not mentioned ever in any sealant guide type articles.
i didn’t know what it was after I saw it in a building supply store so I looked it up, and it seems to be better than all the other window door siding and/or all purpose sealants out there at least for what I’m looking for in a sealant. To me, it has better characteristics than the hybrids, tripolymers, silyl/silane modified polymers, advanced polymers, etc.
https://www.chemlink.com/chemlink/media/Chemlink/Resources/TDS/DuraLink-50-7-2-18.pdf
And heres another except this is a silyl modified polyether (don’t know how green this particular one is)
https://www.bostik.com/us/Bostik-products/pro-ms50-construction-sealant
anyone have experience with these products? Are they new?
Not a big deal but I am also a little curious as to what it means to be a sealant and also an adhesive.
Kevin,
I wrote a pretty extensive article about caulks and sealants for Fine Homebuilding and didn't come across these products, but I just realized that was now 15 years ago. How time flies. At a glance these two products have a lot of attractive characteristics. It'll be interesting to see if any GBA members are using them.
Boy, it is really hard to find explicit and delimiting definitions of the terms caulk, sealant, mastic, etc.
Here is my quick cut:
1. adhesive: meant to be applied between two substrates to augment fastener connection of the two substrates. Adhesives are meant to be compressed/trapped.
2. sealant - usually means liquid sealant and applied as a 3-D bead. These are meant connect two substrates, NOT compressed, and also installed with either backer rod or bond break tape to limit their attachment to the substrates to two unconnected planes, so that the sealant accommodates movement in connecting the two substrates.
3. mastics: sticky stuff meant to seal surfaces, often left exposed
4. PSA tapes: pressure-sensitive adhesive tapes meant to seal substrates and often accommodate some movement in the substrates regardless of whether or not the substrates are exposed or trapped by subsequent layers of the assembly.
the most common chemical composition of many of these sticky materials include latex, modified bitumen, butyl, acrylic, silicone, and silyl/silane modified polymers. Each vary in their elasticity, accommodation of movement, environments they tolerate, strength of adhesion, outgassing, and cost.
that clears things up, right?
Peter
Peter appreciate the response. I just meant what is a sealant-adhesive technically speaking. I’ve seen sealants, and I’ve seen adhesives, but never sealant-adhesive. Just recently came across some when I was poking around looking at the polyether world. I can’t remember if the polyether was the sealant-adhesive, or if those manufacturers happened to make sealant-adhesives that I noticed on their website. Perhaps it’s just a way to say their sealant bonds/adheres really well, in general? Or they are flexible adhesives that are classified also as astm c920 class 50, which perhaps there is demand for somewhere...? I think it sounds cool
Edit: here’s one-
https://www.chemlink.com/Products/Multi-Purpose/SKU-8252-DuraLink-50-Super-Adhesion-Sealant
And another-
https://www.bestmaterials.com/detail.aspx?ID=10901&gclid=Cj0KCQjwgLLoBRDyARIsACRAZe5PzZ31UVFPLNz6G32uiDrLeOru_LAgmPjMcNLpZ4U0BMjfw_QOcsUaAtJUEALw_wcB
IMO, a good adhesive needs good adhesion, tensile strength and shear strength. This can be useful in some cases - if you prevent movement, then you need less movement capability.
What specification of polyether do you consider superior to a polyurethane sealant like Demonic 100? Specs on the former look worse to me.
