Polycarbonate “glass” block
[email protected] | Posted in Green Products and Materials on
I’m trying to come up with translucent, bullet proof walls, and had a thought that a “glass” block, made out of polycarbonate would be bulletproof for small arms fire. I can find acrylic block, but not polycarbonate.
Does anyone know of a manufacturer/source?
  1. KeithH | | #1
    Well, I'll ask since someone is thinking it. What's this have to do with green building? Good luck with your search!
  2. user-2310254 | | #2
    You can buy "bulletproof" polycarbonate sheets cut to size. Would that work or are you "shooting" for a block look?
  3. charlie_sullivan | | #3
    McMaster Carr has polycarbonate up to 2" thick. A 6x12x2 block costs$333. They are a distributor that specializes in making a wide variety of materials readily available, not in low prices. So maybe you can get it for $100 directly from the manufacturer. Maybe 3" thick is enough, and 3x4x12 is the same $100. Three of those for a square foot so that's $300 per square foot.
    It's not UV resistant, so you'll need a covering or coating for that.
