Poly under slab on grade…
![](https://secure.gravatar.com/avatar/485e8b552771c4056f0b9f9f3a96fb24?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fh.png&r=g)
I’ve understood that poly sheet plastic of at least 6 mil should go directly under a cement slab on grade. At times I have read that the poly sheet can/should go below the rigid foam. I will be having pex imbedded in the cement slab, for radiant heating, if this makes a difference. Is there a preference on where the poly sheet goes?
Link:
"Polyethylene Under Concrete Slabs"
