Plywood Forms for Concrete
![](https://secure.gravatar.com/avatar/9f0e1d7a4daefe8fcedcd01b2e374050?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fs.png&r=g)
Hello,
I am looking for advice on forming up my grade beams for my 1000 square ft. rectangle of a house. Its for a concrete free slab/ sand box and the structural engineer specified 1 foot wide grade beams that can be done in a single pour. Its trenched on 3 sides and will sit on 6 inches of compacted gravel all the way around. The site has a 10% grade. The western wall will be a 2 foot pour and is trenched. The eastern wall , meanwhile, will be a pour of 42 inches and will not be trenched, thus accommodating the slope of the site. The north and south walls will be tapered between the two.
So, the 1 foot wide, 42 inch tall eastern wall is my biggest concern. I am a carpenter but have largely avoided form work over the years.
Here what I have so far:
1. I am looking for advice on ties. I am leaning towards sandbaggy snap ties and they will be independent of the studs and whalers (not tied in). What is the suggested spacing in this case?
2. Plywood. I would like to use 5/8 zip, since I could reuse it, but would 3/4″ be best for a 1 foot wide pour? Finished side in and presoaked (sprayed) to help with cleaning up the forms, right?.
3. Studs and whalers. I will use 2×4’s. I imagine a grid. Which is best for bracing, having the studs or whalers make contact with the plywood?
Thanks,
Stephen
“ I am leaning towards sandbaggy snap ties and they will be independent of the studs and whalers (not tied in)”
I dont understand what you are saying here? Snap ties are designed to catch the whalers.
I don’t think I would use zip. It will get very messed up in form work and I wouldn’t trust the barrier after that, along with the holes in it, and most spacing guidelines are designed with 3/4 in mind. Also keep in mind your ply direction affects the spacing as the strength degrades when it’s grain is parallel to the support.
Take a look at some snap tie guides to get your spacing, there are multiple with a quick google search.
Hopefully you will get some concrete guys input but you might have better luck with that on FHB
