Attic Plywood Air and Vapor Barrier
![](https://secure.gravatar.com/avatar/1e7b7a3eb144fb7b4179f77f7d0116c5?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
I have been planning to use a 5/8″ plywood + tape to create my air/vapour barrier between my conditioned space and the attic. My walls are ICF and the plywood would be taped to the ICF foam.
I am in zone 6A in southeast British Columbia. It sounds like the local inspector may still want us to use a poly barrier. I wanted to avoid this because of added cost, durability, and the PITA nature of any penetrations.
Is there any code/literature that I can point to to help ease his mind? I’ve found these articles, but I would classify them as good, but not great resources:
https://www.ecohome.net/guides/2289/interior-sheathing-as-an-air-and-vapour-barrier/
