PEX manifold systems
drrossw | Posted in General Questions on
Is there any reason to use a manifold system on the cold supply side besides the convenience of maintenance on fixtures?
  1. charlie_sullivan | | #1
    There's no energy efficiency reason, but there is one other reason, which is that you avoid the effect that turning on one fixture changes the flow rate in another fixture--the classic version of that being that flushing a toilet changes the temperature in a shower. That's less of a concern than it used to be, because modern shower valves are much less susceptible to that problem.
    Ross,
    Many plumbers don't like home-run systems with a manifold because they require so much tubing.
    One touted virtue of these systems is that water pressure remains stable to all fixtures when several are used at the same time.
    I think that it's fair to say that there are pluses and minuses to both approaches -- the home-run approach and the trunk-and-branch approach.
