perimeter insulation for slab heat
I have 2″ rigid insulation 2′ deep around the inside perimeter of the garage. I plan to add another 2″ 5″ deep for the slab itself. My questions are:
1) do I cut the foam at a 45 at the top so the concrete fills in closer to the walls; or do I leave a 4″ foam “joint” around the inside of the garage floor? If I do cut a 45, doesn’t that remove much of the insulation around the perimeter of the slab? Or, do I just cut a 45 angle an inch or so down, so I get a skim coat to cover the top of the foam?
2) What do I do at the door openings? I plan to have a 10′ apron in front of the doors. Where do I put the foam for this? Inside the garage seems to allow the outside cold to get under the doors; while outside may not insulate the inside from heat loss thru the walls. Do I run the foam as high as the top of the slab, or to the bottom, so the slab can extend into the apron? Do I end up with a 4″ “joint” between the slab and the apron? Would this joint break down from weather and driving over it?
Thanks for the comments.
Tom,
Martin's basement article goes into some detail on best practices for protecting exterior foam.
https://www.greenbuildingadvisor.com/article/how-to-insulate-a-basement-wall
