Performance Tape Removal
pico_project | Posted in General Questions on
Has anyone had any luck removing performance tape from a surface?
Someone thought it would be a good idea to use Fentrim as a painters tape to protect some concrete block from paint and then trim it later. Of course it doesn’t come off cleanly and leaves a sticky residue that dirt just sticks too.
Has anyone has to remove tape before? What would be something safe for concrete that would also remove the sticky residue?
    Akos | | #1
    Fentrim is pretty expensive painters tape! I've used acetone for removing acrylic adhesive from EPDM, you can try that or goo gone. Won't be fun on concrete.
