Patching holes in sheetrock?
![](https://secure.gravatar.com/avatar/09adb76e5eb91b94378f8c7d0de76d0e?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fs.png&r=g)
What’s the best way to patch holes in sheetrock made by hanging pictures, etc.? They’re too big to spackle and I want a nice smooth surface after I’m done.
Sheleen,
The smooth finish is obtained by careful application of joint compound (usually two to three layers, which are allowed to dry between applications) and careful sanding.
Larger holes require paper tape, fiberglass tape, or a piece of drywall to make the patch. You can also buy a drywall repair kit at most hardware stores.
More information here:
Small Drywall Patch
Repairing Drywall
These holes (1/4") are too small for a drywall patch and too large for just joint compound. Do they mean tape over it first? Or can I use some dowling to plug the holes and then joint compound over it? Also, it's in the bathroom, so humidity is a factor.
Sheleen,
A 1/4-inch-diameter hole can be patched with ordinary joint compound or Spackle. No tape is needed.
