Partial encapsulated crawlspace?
![](https://secure.gravatar.com/avatar/5c208b912a8db9dfff9c5361361a0d1d?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fb.png&r=g)
Hi All,
My vented crawlspace was built 2 years ago in climate 4C.
From what I read and observe, ventilated crawls are not perfect in this climate, but are not automatic disasters like in other climates.
That said, There are already large cobwebs down there and I can only imagine things will get worse. I would like to begin the encapsulation process with a nice white vapor barrier and eventually cover the vents up.
But the floor insulation looks perfect and is essentially brand new, I am not ready to tear it out. Is there a hybrid encapsulation approach? Can I add a vapor barrier, cover vents, and skip the concrete stem wall insulation?
I do not have mechanicals down there and there is already a 6 mil black plastic barrier layer on the dirt but not taped. Any suggestions?
Thanks
Don't cover the vents without a properly encapsulated and conditioned crawlspace. But you could use insulation and/or vapor retarders to improve the performance of a vented crawlspace - less cooling and less ground moisture entering should be beneficial.
