Panasonic ERV for the whole house
![](https://secure.gravatar.com/avatar/e3fa65b331848df3c57320c53ded7e9e?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fk.png&r=g)
The Panasonic WhisperComfort claims it can be used for the whole house.
The 40 cfm rating is plenty for two people in a 1200 sq.ft. house
Has anyone seen a report or have experience that it does the job adequately?
$300 at WalMart makes it pretty compelling
http://www.walmart.com/ip/WhisperComfort-Spot-ERV-Ceiling-Insert-Ventilator-with-Balanced-Ventilation-and-Patent-Pending-Capillary-Core/17420463?srccode=cii_9324560&cpncode=30-69407109-2&adid=1500000000000036337730&veh=cse
I should mention I was worried that there would be "short circuiting" with this design.
Has anyone seen a report on how to commission an ERV?
Kevin,
It all depends on the layout of the house and the expectations of the homeowners. I imagine that the Panasonic ERV will work better than an exhaust-only system -- and plenty of people are perfectly satisfied with an exhaust-only system.
Martin,
Since the WhisperComfort is only $200 more than a Panasonic exhaust fan, that's a very small risk.
Perfect if not overkill. I have a customer with one installed in a spray foamed open loft one bath home and all is good so far. Large crowds, they open windows and doors... birthday gatherings etc...
