Options for trapezoidal clerestory windows that won’t break the bank?
![](https://secure.gravatar.com/avatar/05293600310e56ef86b8b0a443efc27a?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fn.png&r=g)
Hi all,
I’m thinking of adding a simple fixed clerestory window above a door on a workshop I’m building. The window shape would be trapezoidal. As a beginner DIY builder, I’m a bit confused about window options.
The location I have in mind is in the attached photo. I’d like to put the window above the door and horizontal band detail and in between the two sets of roof beams. I did not actually frame this area for a window, but I believe no special framing is necessary since the roof load is carried by the roof beams. I can have the engineer that approved my plans double check.
So what are my options here? I know this might seem like a very basic question but I really don’t know where to go for a more specialized window unit like this.
Nic,
Window manufacturers will build any shaped window you want. They just cost more than their standard sized units.
