Options for roofing underlayment for lower sloped roof
![](https://secure.gravatar.com/avatar/5c208b912a8db9dfff9c5361361a0d1d?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fb.png&r=g)
I’m guessing with a lower slope and standing seam metal planned, one would want a little more robust underlayment than heavy tar paper.
What are good options for this? Something self adhered?
thanks
I am not an expert of building materials so please double check - Solitex Mento 1000 from ProClima appears to be a good fit for this application. the 3000 even includes self-adhesive strips. not cheap!
I usually see high temperature underlayment recommended for metal roofs. I used Hydraguard Dual Pro High Temperature Ice & Water Barrier from Menards. https://www.menards.com/main/building-materials/roofing-soffits-gutters/roofing-underlayment/building-materials/roofing-soffits-gutters/roofing-underlayment/hydraguard-dual-pro-high-temperature-ice-water-barrier-39-3-8-x-61-200-sq-ft/1511833/p-1464866315609-c-13250.htm?tid=-5369144774740139514&ipos=6
It's fully adhered and has a non-woven fabric surface to act as a slip sheet. At $.45/sq.ft. it seems reasonable.
Hi Joe -
I would consider the vapor permeability of the roofing underlayment and whether or not your roof assembly is vented, and/or needs to having drying potential to the interior.
Peter
Rhino Roof U20 is probably your most cost effective underlayment. Under 4/12 pitch requires 2 layers but is a lot lighter than 30# felt and a lot stronger.
High Temp ice and water shield--whatever the brand. I just did my 2:12 roof and that is what was spec'd
