Opinions on the VENTS-US single room ductless ERV?
![](https://secure.gravatar.com/avatar/74dd5e4e26f39f37c9a385a8abcaba30?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Ff.png&r=g)
VENTS-US single room ductless ERV units
Any familiarity or opinion about the VENTS-US single room ERV called TwinFresh Comfo. Are the performance claims any good? For apartments, lofts, cottages and small homes? Can they be used in same building where exhaust-only ventilation is in the bath and kitchen?
http://www.ventilation-system.com/cat/618/
Apparently Home Depot is where they sell:
I've been trying to call the given contact number for vents-us.com
to ask about the fact that the "cycling" methodology is likely to
alternately pressurize and depressurize the building, turning it into
a moisture pump. Calling just goes to some unspecified voicemail.
Now if you could install two of them and *synchronize* their cycles,
you might have something...
_H*
