Open-cell foam in an unvented cathedral ceiling
![](https://secure.gravatar.com/avatar/243fb8118c8757c304431a5be211a514?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fn.png&r=g)
I’m getting quotes from contractors right now to insulate a small cottage with an unvented cathedral ceiling using 2x10s. I’m in zone 3C.
One contractor has suggested spraying 5.5″ of open-cell foam between the rafters and calling it a day. I asked if we could just fill the entire 9.5″ cavity and he said, “You achieve maximum efficiency @5.5. Any more is overkill. It will expand a couple more inches as we will not cut it but leave the excess.”
Code requires R-30 for ceilings around here.
I may be wrong but doesn’t more insulation mean higher R-value?
Is there a maximum efficiency for certain insulation materials?
Another contractor has proposed 1 inch of closed-cell foam and filling the rest with blown dense pack fiberglass. No one that I’ve talked to wants anything to do with cellulose. Maybe it’s a west coast thing.
Your opinions are greatly appreciated.
Nicholas,
Q. "Code requires R-30 for ceilings around here."
A. To achieve R-30 with open-cell spray foam, you need at least 8 inches of foam.
Q. "Doesn't more insulation mean higher R-value?"
A. Yes.
Q. "Is there a maximum efficiency for certain insulation materials?"
A. Every time you double the thickness of an insulation material, you double the R-value. Of course, at some point the cost of the increased insulation is more than is justified by the amount of energy that is saved.
I don't recommend that you install less than the minimum required R-value under the building code.
One issue with all of the methods you have described is that they don't address thermal bridging through the rafters.
For more information on insulating a cathedral ceiling, see How to Build an Insulated Cathedral Ceiling.
Thanks, Martin. I've read your article about building cathedral ceilings. It's a great resource. Regarding thermal bridging via the rafters, do you suggest that I install 1x strips across the rafters and have the installer fill the insulation flush with the strips? That would cover a majority of the rafters with a bit of insulation.
Nicholas,
One inch is something -- certainly better than nothing. How about 2 inches? That would be better.
