Off-the-electrical-grid propane water heaters — either tankless or tank
bullbranch | Posted in Mechanicals on
Off-the-electrical-grid propane water heaters — either tankless or tank.
Only for 2 person use, one bath, one kitchen.
What manufacturer do you recommend?
  1. GBA Editor
    Martin Holladay | | #1
    Mike,
    Whatever water heater you choose, make sure that it does not require any electricity. That means you shouldn't choose a power-vented model.
    I suggest that you choose a simple, bottom-of-the-line tank-type heater. Make sure that it can be serviced by a plumber or gas technician in your area. Don't choose anything unusual or imported.
