Occasionally heated garage
![](https://secure.gravatar.com/avatar/e6eca528abcc2e70a58baf9eec8a036b?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Ft.png&r=g)
We are getting ready to move into a new place for a while, and the garage is separate from the house. It is stick built with OSB sheathing and T111 siding. I would like to insulate it and get ready for the zone 7 winters we have in Northern Wisconsin. I may need to work on a vehicle project.
This is a duplex and we are only planning on living here a couple of years max, so I don’t want to invest too much.
Would Tyvek after fiberglass bats cause any problems? I am wanting to have an air barrier more than vapor since the vapor goes through the Tyvek in and out. I just want to maintain the heat I temporarily need to keep in the enclosure while I am working.
Would poly be a better choice? I have some left over Tyvek, so the cash would be minimal for it.
Same thoughts on the ceiling. I would put some baffles in at the eaves and put up the Tyvek. Then strap underneath with 2x and the ceiling before blowing in cellulose.
I need to practice cellulose for another project.
Any thought/suggestions would be great. Thanks
the74impala,
I don't see any problem with what you are suggesting. You might want to just use 1"x4"s for the ceiling strapping.
Only reason I thought 2 x 4 on end so I could keep all the electrical boxes on the inside of the air barrier.
