Occasional buzzing sound Daikin minisplit
![](https://secure.gravatar.com/avatar/ca5d7e21b51621e0caa4fa58db066c96?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fb.png&r=g)
I recently bought a house with Daikin mini split units on the second floor to provide heating and cooling – the unit in the bedroom will randomly buzz for a second or two at a time and it can repeat every 10 seconds or so for a few minutes, then stop for a while – it even continues to do it when the unit is powered off – i recently had to have the freon refilled and recharged but otherwise it seems to be working fine – is it a problem with a water pump that removes moisture from the air? the unit in the bathroom does not do that sound so i’m assuming its something that needs repair or replacement
