Nyle Geyser RE problem
![](https://secure.gravatar.com/avatar/2c324c54b31279af085344000ece0703?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fa.png&r=g)
I’ve seen the Geyser RE mentioned on this forum numerous times, so I am hoping someone can help me troubleshoot my unit. I installed one this summer, connected to a new 80 gallon State electric water heater. It worked for a couple of days and then starting tripping the circuit breaker. It was a 15 amp circuit (I was using a 25′ 12 gauge extension cord to reach it which tech support had ok’d beforehand). I thought maybe the combo of a 15 amp circuit and the extension cord was the problem, so I wired a new dedicated 20 amp circuit right next to the unit, but the problem persisted.
Tech support sent me a new relay, but that didn’t fix it. I hooked up a kill-a-watt to it and observed it for a cycle. It would run for about 2 hours, then start to shut down. But right at that point the compressor would kick back on, but not circulate water, and it would be drawing 0.33 amps (not the 4-7 it does during normal operation). It would run like this for several hours until the breaker tripped.
I reviewed all my connections and wiring. I plugged a dehumidifier into the same outlet and it ran fine for days. I sent the unit back and they can’t find anything wrong with it and have never heard of the unit shutting down a cylce but then the compressor kicking back on until the breaker trips.
Anyone have any ideas? Right now they still have the unit, and I am not sure how proceed.
Thanks.
They should send you another one, and then figure out what went wrong with the first on their own time.
