Non-electric Fresh Air vents
![](https://secure.gravatar.com/avatar/685834e9d8830d0c5cca46ed184f5eaf?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fs.png&r=g)
I am considering using the Lunos type of ventilation fans which seem to require electricity all the time in order to work. Has anyone used these non-electric ventilation devices?
This is for an off grid cabin run on PV panels.
Aren't these make-up air intakes?
Scott,
These devices are basically a hole in the wall. You can achieve the same effect by cracking a window open.
A makeup air vent (a hole in the wall) is designed to allow outdoor air to enter a house that has been depressurized by an exhaust fan. They usually don't work as intended, because they are overwhelmed by the stack effect and wind.
