No WRB behind soffit
user-1102988628 | Posted in Energy Efficiency and Durability on
Hi,
Builder did not install WRB behind soffits. Please share thoughts.
Thanks
h
  1. Malcolm_Taylor | | #1
    User ...227,
    As long as the WRB is not being used as an air-barrier it should be fine.
    Under our code here in BC, we can not connect the rain-screen cavity with the roof above as you have done.
    1. user-1102988628 | | #2
      There is an over roof (plywood deck taped with strapping and zip above taped.). The wrb is being used as the primary air barrier:(
