No cllue
UhNope | Posted in General Questions on
I have rats that are going to the edge of the attic where the rafter meets the floor. They are penetrating at the edge straight down and getting into the walls . what is the best effective way to prevent this? I’m thinking flashing It is still enough to pull up against that angle with after the floor meet.
Also, I am replacing the plywood walls in a shop outback will need to replace possibly some studs due to mold and chewing good ideas for building into the return so I won’t have to exclude after they start Chewy holes?
    BILL WICHERS | | #1
    1/2" hardware cloth usually makes a good critter barrier. Flashing will work too, but I'd use galvanized steel flashing, not the usual aluminum stuff.
