New wood foam!
![](https://secure.gravatar.com/avatar/f535c0c299c0e99bd8b21c2ec90a781f?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
http://www.gizmag.com/wood-foam-insulation/31133/
Might not be news to all of you,
but it is the first time i read about it in this form.
Seems kind of promising in terms of base material used.
If it can be “foamed up” using co2 or other natural gases …
If it uses a low % of material VS air once it is foamed,
it could be very very cheap to supply
( as in using a mix of many wood industry residues )
Even greener if the natural wood “glue” is used in the biding process!!
Then, what about resistance to insects and fungus ??
I still prefer the inertness of “rock wool” though.
