New Mitsubishi FH06NA ductless minisplit
![](https://secure.gravatar.com/avatar/4ac6931384398f1839dc2f09325ab80d?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fp.png&r=g)
searched, couldnt find any info posted here;
looks like there is a new, smaller Mitsubishi Hyper heat [6000btu] available for pre order
seems like this is a good new option for increased flexibility/zoning.
hope that helps
https://meus.mylinkdrive.com/files/MSZ-FH06NA_MUZ-FH06NA_ProductDataSheet.pdf
It doesn't look like this modulates any lower than the 9k btu version, so did they just take the 9k and limit its top output?
It's probably smaller/cheaper coil &/or compressor on the outdoor unit, and perhaps more subtle engineering tweak on the wall coil.
The housing dimensions of the FH06 & FH09 head and outdoor units are identical- there may have been a software change to optimally use a smaller/cheaper compressor in the outdoor unit. (That falls under "random speculation" here on my part.)
The HSPF of both are the same (13.5) , but the SEER of the FH06 is about 8-9% higher (33.1 instead of 30.5):
http://www.centralmaineheatpumps.com/sites/default/files/ec_pro/centralmaineheatpumps/MSZ-FH09NA_MUZ-FH09NA_Submittal.pdf
On the same web-store the FH06 is $108 cheaper than the FH09, and they claim to have two of the FH06 in stock (as of 2 minutes ago.)
Ooohh. Shiny. OK that aside, smaller heads or better performing multi heads are somewhat essential to retrofit applications as not every layout can accommodate a single large head effectively. I'm excited to see this trend even if it looks like maybe it's not really new equipment.
