New home in DE
![](https://secure.gravatar.com/avatar/1472ae723c939884f267acc01a4dab5d?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fe.png&r=g)
Plan to sheath with insulated ZIP 4×8 panels. In the interior looking at the 2×6 stud caviity should I caulk the Zip insulation to the stud or is there enough pressure from nails to seal same?
Thanks
Ed
The nailing schedule is sufficient to insure sufficient attachment to the studs so the answer is no you do not.
Edward,
This is the third time you have posted this question (or a comment on your question) on GBA.
Are you having problems finding your previous posts (the first of which has several answers)?
If so, here are links to your previous posts on the same topic. Visit these pages to see how GBA readers have been answering your question.
1. Building new home in Delaware and using insulated Zip exterior sheathing
2. home in DE
In the future, please post all comments and additional questions on the first thread you created (Building new home in Delaware and using insulated Zip exterior sheathing).
