New construction lumber Lots of worm holes in wall studs
![](https://secure.gravatar.com/avatar/d2644db97852e999cfbc289e909c85df?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fa.png&r=g)
Hello experts,
With no quality experience I signed up for my first house with a renounced local builder in north Dallas area (Celina). Now they are framing it. I found studs they are using in my house has countless strange holes (see attached pictures). these studs also look different (more lighter in color). I do not see any other construction in that community with this kinds of lumber.
what grade of studs they are? Looks like these are these damaged by termite/worms. Can builders use these kinds of damaged lumbers?
If this is a concern, could you please advise what should I do in this case?
Please help.
I've never worried about a few insect bores and color of the studs. Some of them do do have quite a few though. You can always ask them to change a few if they bother you that much. I would be more concerned about the use of finger joint studs in structural applications.
