New bath fan vent placement – seeking advice
![](https://secure.gravatar.com/avatar/b27f2f4fadbdceb8e1e74b90241b130e?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fl.png&r=g)
We have a first floor bathroom on the home’s gable end that currently lacks a vent fan. I plan on installing one next weekend, but am seeking advice on the fan’s exterior vent placement.
I think I have two options:
1) installing a ceiling fan and running a 12-ft rigid pipe through/parallel with the floor joists and out the back end’s vinyl siding. This places the exhaust vent ~10-ft below my attic’s soffit vents.
2) installing a thru-wall fan through exterior brick. This places the vent ~10-ft below my gable vent.
I prefer option 1 because of interior fan aesthetics and the fact I don’t need to drill through my 1950 Cape Cod’s brick. My only concern is the exhaust’s proximity to the soffit vents – is 10-ft close enough to potentially cause issues?
Many thanks in advance!
BTW, the house is in climate zone 4-A if that helps.
Also have a follow-up question - if I go through the vinyl siding, what is the best way to detail the exterior vent cap? Cut the siding and mount the cap to trim block or screw the cap directly to the siding?
Look for the manufacturer's installation guide, but typically by code, you need to stay 10' from any air intake. It does look like option 1 is best, IMO.
Hankla,
Through the vinyl siding will be easier than through the brick. The distance from the soffit vent shouldn't cause any worries.
Many suppliers sell vent terminations designs for vinyl siding. Here is an example:
https://www.doitbest.com/products/107719?via=57c72f3d69702d410a0032ec%2C57c72f5669702d410a00347c
