My wall construction is 2×4 filled with cellulose and 4-1/2″ urethane screwed to the outside.
![](https://secure.gravatar.com/avatar/c7de49eaea8276c03dd5c0651c209d79?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
My wall construction is 2×4 filled with cellulose and 4-1/2″ urethane screwed to the outside. Is there an advantage to put a 1″ air space between the 2 insulations? If so how much does it improve the R value?
Thee wall has an R-45 without the space.
Q. "Is there an advantage to put a 1" air space between the 2 insulations?"
A. No. An air space increases the chance of heat-robbing infiltration and exfiltration, as well as heat-robbing convection loops.
