My question is ice dam related. I am looking for a permanent solution.
![](https://secure.gravatar.com/avatar/9d98ab65baa0ffab3ea0fcdecf70745c?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fa.png&r=g)
I get ice dams near my gutters every year and would like a permanent solution. I am in the process of getting it air sealed and insulated but I have solid soffits with small vents about every 6 feet. s this enough ventilation and if not what can I do to make it right? Thanks in advance.
Al,
If you can get a good air sealing job, and at least code-minimum insulation (generally R-38 or R-49, depending on your Climate Zone), you should be fine. For more information, see Prevent Ice Dams With Air Sealing and Insulation.
If your gutters extend above the plane of your roofing, however, the gutters are probably contributing to the problem. When in doubt, it's usually a good idea (in snow country) to remove the gutters, unless you have another compelling reason (a wet basement, for example, or a splashback problem) to keep them.
Thanks, I will double check the gutters but I think they are even or just below the roof line.
First winter we built we had heat on (for construction) but no insulation. That winter the snow melt filled the gutters with solid ice and huge icicles over the side. They are heavy galvanized gutters so they handled the weight and my periodic effort to break out the ice with a hammer. The next winter we had installed insulation and the roof deck was air sealed. To prove the point, we had not a single issue with under-the-snow-melt nor the ice dams and icicles in the gutters. Removing gutters will replace the daming with icicles but might stop the ice backing up under the shingles.
