Multiple condensers vs multiple heads
![](https://secure.gravatar.com/avatar/4f554437abc4481fad5f364a5163dbc8?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fs.png&r=g)
A quick search found little info , I am curious on the virtues for multi head ductless vs multiple stand alone mini splits. How much of a penalty would be paid for electric usage? I see more wiring , having a breaker and disconnect for each, however the upside that if one went down you would have backup. Obviously you would need to do this in a situation where you had heads on different ends of a larger home. My other thought is you could mix and match units. Like using a hyper heat version on the lower level and a non hyper heat on a upper level where the load is more biased to the AC side.
Comments..
