Multi-speed inline exhaust fan
![](https://secure.gravatar.com/avatar/bdb5cb691ec733567453079262e8d2de?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
Is anyone aware of an inline exhaust fan that has multiple speeds so it can do low continuous ventilation and on-demand ventilation?
–John
John,
You should look into Fantech's "mixed flow" fan line.
http://www.fantech.net/products/fans--accessories/circular-duct-fans/circular-duct-fans-with-ec-motors/fkd-ec/fkd-12-xl-ec-mixed-flow-fan/
Contact Fantech for more information.
-- Martin Holladay
John,
I went looking for just this item at one point, but for lower flow than Martin's example, and came up with these (I've never used these so I'm just forwarding the data on it with no recommendation):
http://www.fantech.net/products/fans--accessories/circular-duct-fans/circular-duct-fans-with-ec-motors/prio-ec/prioair-6-ec-inline-duct-fan/ (continuously variable speed, also Fantech)
and
http://vents-us.com/images/cat/706_301_cat_file.pdf (two speeds)
And I'm sure there are others.
Fantech was the right direction. The FG EC series looks the most reasonable. They're electrically commutated, efficient, can be controlled by 0-10V signal, and are available down to 180cfm peak. They're also energy-star and HVI rated. It's not clear if they're appropriate for venting moist air, but I'll ask Fantech.
Thanks much!
--John
Fantech says the FG EC series is appropriate for bathrooms.
--John
