Moovair heat pump
![](https://secure.gravatar.com/avatar/b4de5cad1c0646ea45c670bae09a57b1?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fb.png&r=g)
Is anyone familiar with the quality/durability of the Moovair Heat Pump brand (https://www.master.ca/consumer/moovair-heat-pump).
We are in Vancouver, BC (Zone 4) and replacing a Carrier gas furnace & AC with centrally-ducted heat pump system. We were initially getting the Mitsubishi Zuba but our house is older and has a low basement height for the air handler. Contractor is now recommending Moovair heat pump system for a slightly lower price. Not much information online about it, so I wanted to see if anyone has any experience with this system.
Thanks,
Chris
Most of these are OEMed by either Midea or Gree. This one looks like a Midea.
The specs are not too bad:
https://ashp.neep.org/#!/product/56618/7/25000///0
Usually these off brand units should be about $1500 to $2000 cheaper than a comparable Fujitsu/Mitsubishi.
Before picking the unit, make sure to go through the calculations here to check sizing based on previous fuel usage:
https://www.greenbuildingadvisor.com/article/replacing-a-furnace-or-boiler
You generally want these right sized, meaning very close to actual load to get the best efficiency out of them. Plus a right sized unit is smaller/quieter/cheaper.
Thanks Akos. I haven't done the sizing calculations - the Ashton Services Group recommended a 3 ton system as our house is about 2500 sq feet. The specs on the 2 ton system you sent above look a bit better in terms of the HSPF and SEER, and the air handler is even smaller.
Hey @bc_chris did you ever get the 3 ton moovair installed?
How's it working out? I've got a quote in hand for something very similar, so if it's not a weird thing to ask, I'd love to come and see (and hear!) it!
I'll...bring chocolate? Or something?
Also, that offer stands for anyone in the lower mainland with a 3 ton moovair... Can I come check it out? I'll bring you cookies lol
Hello bc_chris and Robotarmy:
did you end up installing Moovair? Care to share your experiences?
