Moisture condensing at base of walls – new build
![](https://secure.gravatar.com/avatar/2a38b1318299df91eca75f588567bc76?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fl.png&r=g)
Hello,
Here’s an interesting one. I have a double stud 16″ exterior wall infilled with straw bales on end and dense pack cellulose. The vapor barrier is definitely doing it’s job but the problem is moisture is condensing at the base of the wall (which is actually a raised floor through which the plumbing travels). Admittedly it’s -40c out so conditions are unusually extreme and the mudders just finished so humidity is high, but there doesn’t seem to be any cold air coming through the wall, and I’m at a loss. If I can’t solve it to remediate it I was thinking a strip of green guard along the base of the wall, with the hope that when conditions are less extreme then it would dry out for the few days when it gets wet a year. Thoughts on this would be greatly appreciated!
Hi Laird,
Have you performed blower door tests?
