Mitsubishi Mini split
Mammy | Posted in Expert Exchange Q&A on
We recently installed mini splits, which will eventually be run by a solar system. In the night, the electric went off, then came back on again, but the mini splits did not? We go away for a month and a half to Florida and I’m worried about these not coming back on again. Is this common? Is it a setting?  Mammy
  1. Josh_Dillingham | | #1
    I have a Mitsubishi minisplit. I dont recall having any issues when the power goes out and comes back on, but I would recommend getting a wireless controller for it like Sensibo so you can check in on the temperature from florida and adjust as needed. It will give you piece of mind that everything is ok back home.
