Mitsubishi FH wall units advanced settings
Does anyone know how, if possible, to access the advanced settings on the Mitsubishi FH wall units? I’d like to program them to shut the fan off when in cool mode and desired temp is reached to prevent moisture being reintroduced from the coil into the room raising humidity. This is the remote. Thanks
I think that generally requires a controller that has local temperature sensing.
Check here:
http://ld3.melsup.com/sfiles/Application%20Note%203048%20ME%20-%20How%20to%20turn%20off%20indoor%20unit%20fan%20when%20set%20point%20is%20met.pdf
Thanks for that link, I've been looking for something like that for a few days now. I have the indoor units that say they require the jumper wire be cut physically, which I find ridiculous, and if you want to reverse it you have to reattach everything. If the kumo cloud allowed it to work that way I would go that route but I guess I'm going to be limited to what I've been doing which is controlling it with an external unit ( Cielo breez) which just turns the entire thing off when the temperature is met. Either that or perhaps a remote thermostat in each room could be set up that way. I would be fine with that set up. I have the MSZ-fh wall units btw .That's the one disappointment I have with the units.
