Miraflex Insulation
![](https://secure.gravatar.com/avatar/23f3a6351fdaf8f3106c02cc3efe9b64?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fl.png&r=g)
I have some old Miraflex Insulation on the attic floor with a pink permeable covering facing the roof deck, and an impermeable layer facing the attic floor.
Should I remove the impermeable layer closest to the attic floor before filling in gaps between joists and adding another layer of unfaced insulation? I will make sure I air seal well.
This is not a finished space, roof is vented, and I live in Southern Ontario.
Thanks in advance!
Hi Linda,
Have you called Owen Corning's technical support number? It's my understanding that Miraflex is a type of fiberglass insulation used in products such as Owen Corning PinkPlus.
