Minisplit Noise
![](https://secure.gravatar.com/avatar/325a5e28ec2caa6521d6132ee27ad307?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fw.png&r=g)
I have several Mitsubishi 6k units wall mounted on an older ~1900 home. I have terrible vibration/noise from all of them. Even on low from the inside it sounds like a diesel truck idling outside. From the outside, no noise whatsoever, I have to look at the fan to see if it’s running.
I have asked my installer to move them down on stands; he wants another $2k for the move. The noise has been a problem from the beginning, and the installer has been unresponsive.
Has anyone had any luck either getting the installer to fix a problem like this, or by going to Mitsubishi getting any relief?
Thanks, Bill
PS, other than this, LOVE the minisplits!
Sometimes using vibration isolators in place of regular mounting bolts (McMaster Carr has these isolators) will make a big difference, but not always. Best is usually to use a stand. You can probably build a stand from strut to mount the units on the ground, and build the stand such that the units themselves don’t have to move much. I think we had a recent poster on here describe how he did just that.
Yeah, they have to be moved enough to require new whips and the units will need to be reconnected after moving. I wish it were that simple, but they hung them up pretty high on the wall, which I think exacerbates the vibration problem. They also already added the isolators.
No easy solution here. The stock rubber mounts do nothing for the low fequency noise from the compressor.
One option you can try is to put the units on proper spring mounts such as these:
https://www.grainger.com/product/MASON-Floor-Mount-Vibration-Isolator-5C126
You can try it on one unit and see if it is good enough. Note that you have to adjust the preload on these to match the weight sitting on it. Check the PDF from the manufacturer.
The unit can move a lot more on these mounts so make sure there there is enough free length of refrigerant pipe to allow for this.
Along with the isolators, adding some mass (~ 200lb) to your brackets, but I can't see an easy way of doing this and also not overloading them.
Ground mount is always the best. Depending on how high they are you can mount it on a post structure and disguise the posts as a trellis.
The easy way to support these is to lean a long ladder along the wall that goes over and past the unit without touching it and support it with a couple of ratchet straps off one of the rungs. You can then take out the wall bracket and build the ground mount under it. This is what I ended up doing with mine, but it was only 4' off the ground.
Akos, thanks so much! Not sure I see how the spring mounts attach to the wall brackets, since they are "floor mounts". I will pursue this and let you know. Still hoping for experience with Mitsubishi helping out on problems like this. Seems like an installation fault.
Those spring units will cost about half of moving the units down to stands on pads, so I guess I'm still stuck with that.
A ground mount will give you the best sound isolation though, so that's a plus. If you want to keep the stand cost down, try using some heavy precast pavers or "deck blocks" and galvanized strut to assemble the stand. Everything you need is available at the box stores. You can have the stand assembled in a few hours this way for probably $100-200 in parts. Just try to keep things level.
Note that if you use deck blocks, you can make things a lot more stable by partially burying the blocks in the ground. I've also used solid concrete blocks 8x8x16 inches buried until only about an inch is above grade. Anchor the strut to the top of the blocks using some tapcons or other type of anchor. Squirting a little silicone caulk into the hole before installing the anchor will help to prevent any freeze/thaw issues with water cracking the blocks.
I don't think Mitsubishi can help much. They can't anticipate the resonance frequencies of your wall system. Resonance is weird. Even the location on the wall can make a difference whether the resonance is amplified or dampened, and at what frequencies. Ground mounts are the only guaranteed fix.
Peter, I agree, but think my installer should have "forcefully" steered me in that direction.
I agree that this is something the installer should have been aware of and that Mitsu needs to build into their training. I suspect they don't because wall mounting is very common in Asia (where the construction is concrete).
Similarly installers should be aware that the units make a loud noise when doing their defrost cycle, way above their listed "max noise" (even when ground mounted as mine were). But installers are either not aware or able to claim ignorance. Fixing the noise of the defrost cycle by moving the compressors also cost me $2k so perhaps that's the default rate for fixing these entirely foreseeable issues!
How does one balance line length and not putting one of these units right outside of a bedroom since from what I'm reading, there could be significant noise?
Make sure you use the recommended line length. Once I moved the units off the house and onto stands there is barely any noise.
You can also help to limit noise transmission by not running the line set straight from the outdoor unit to the wall. Form a good-size "U" bend as a sort of vibration isolating section. The "U" acts a little like a spring, limiting the transmision of vibration which is where the sound comes from. Limiting rigid couplings (such as straight pieces of pipe) between the unit and the wall is the best way to limit sound transmission.
Zephry, where precisely does the "U" go? Between the flared connection at the outdoor unit and the line hide on the exterior wall?
It depends on the installation, but basically, yes, you want it somewhere between the connection on the outdoor unit and the point at which the lineset enters the wall. The idea is to provide a curved length of tubing between the wall and the outdoor unit that can act a bit like a spring and absorb some of the vibration instead of transmitting it through to the wall. It is rigid connections between the outdoor unit and the wall that transmit vibration, and that vibration sets up resonances in the wall which is where the sound you hear is coming from. By limiting those rigid connections, you limit the amount of vibration transmitted which reduces noise levels.
I would typically recommend the line set exit the outdoor unit, make a 90, go up maybe a foot or so, then "U" back down a foot, then 90 and into the wall.
Bill,
Does this also help create a "drip spot" so water runs off there. Is that important?
I'm finally moving forward with our ductless installation. Are you aware of a best practice installation guide? (Through wall PVC or sleeve, penetration boot, on stand etc.) I've been piecing it together from reading different articles but can't find a definitive one. Thanks.
You don't water to run down the line and into the wall, so I suppose the loop could help with that. I'd seal the wall regardless of the loop though.
I like to sleeve passages through the wall, since it makes future maintenance easier. I would use a boot on a roof. The old way was a pitch pot on a roof, but don't do that -- they aren't reliable, and they make maintenance much more difficult.
NEEP install guide is the closest I could find.
https://neep.org/sites/default/files/Installing%20Air-Source%20Heat%20Pumps%20in%20Cold%20Climates.pdf
Are the "isolators" currently installed actually isolators? Both mini splits I got, one a DIY and one professionally installed just had rubber pads between the bracket and the unit mount, secured with a bolt. That bolt completely negates any damping the rubber pad might provide. If that's what you have now, it would be worth trying rubber isolators. It's a rubber block with threaded rod fused to either side. They are pretty cheap.
Trevor, do you have a link for these?
Thanks, Bill
This is just an example, you will need to check what size you need.
https://www.amazon.com/Anti-Vibration-Cylindrical-Vibration-Isolation-Compressors/dp/B089GX4788/ref=mp_s_a_1_3?dchild=1&keywords=vibration+isolator+mount&qid=1615768330&sr=8-3
If the pads are the type I'm thinking of, the bolt is there to prevent tip over and things like that, it's not supposed to be tightened all the way. The bolt acts to stop excessive vertical travel, but should have a gap between the nut and the top of the foot over the pad. If you tighten that bolt, you clamp the unit and cancel most of the vibration damping ability of the mount.
Better rubbed vibration isolators have threaded studs on either end of a rubber cylinder or block. The rubber can go into either compression or tension with these and still function to damp vibration. These are better than the pads with stop bolts.
I prefer spring isolators though, but they're more expensive and less flexible in terms of how you can install them. The best option is to install the noisy unit on a mass block (usually a concrete pad), with that block suspended or supported by spring vibration isolators. This is how large pumps are typically installed in commercial buildings to prevent vibration from getting into the floor and travelling through the building.
Funny, but from your post I thought you were saying that the inside units are making noise. We had this problem on some of our units and it was solved by putting a small wedge behind them so they were tight against the mounting bracket (we actually used butter knives on both corners of the wall unit until I could find wedges). You could use wood shims.
If the noise is from the outside units then I agree mounting on a stand works best. In coastal flood zones, we typically mount them on platforms made of pressure treated 4x4's. I have seen them up as high as 10 feet to avoid mean flood level. If you attach the platforms to the house for stability, use rubber grommets to isolate any vibration and you only need one or two attachment points if your platform is sturdy to begin with.
This was an older post that GBA was reposting. It's a good topic to revisit as people turn to mini splits for heating & cooling needs. This has been an interesting read, and sorry Bill had to go thru this. Curious, what was the outcome / resolution?
We almost purchased wall brackets, then thought better of it, and ground mounted both our units. Glad we did.
Also, I spent time up front extracting decibel ratings for both the indoor and outdoor units from the manufacturer. The goal was to have a unit to serve bedroom areas, but we needed to mount it in a way that compressor noise would not infiltrate thru the wall or nearby windows. I found that not all manufacturers publish decibel ratings, especially on the outdoor unit, or make it easy to find, but sound and location placement should be a priority consideration for any installation. I hope many reading will learn from Bill's experience, and make us of some of the creative ways to ground mount that are offered up in this thread.
I am amazed at how quiet these units are. We have neighbors quite a distance away ( over + 50') with a conventional, ground mounted trane compressor for a/c during summer, and it drowns out any noise from the mini split compressors. The outdoor compressor units run near 50-60 dB on average. The indoor unit operates on average at 39 dB, quieter than our dishwasher(44 dB rated).
I have five LG - 12k Cooling + Heating - 25.5 SEER, condensers mounted on stainless wall mounts that weigh about 94 lbs, but most of the weight is biased on the compressor verses the fan. I used 27+ lbs rated gel mounts under the compressor vibration mount # V10Z61MTHTW ($80 each) and I used 18+ lb rated gel mounts for the fan side of the condenser vibration mount # V10Z61MMN10 ($61 each!), each unit will need four vibration mounts (~$300 per condenser!!!), but it works and the wife stopped complaining!!! If I did it again, I would just get all V10Z61MTHTW's with the higher weight rating..
It cost me some money, but no more vibration or sound, just the quiet whisper of the inside unit.
http://vibrationmounts.dev.inquestmarketing.com/V110/PDF/1_4_Double-Studded%20Silicone%20Gel%20Vibration%20Mounts.pdf
http://www.vibrationmounts.com
Phone: 516.328.3662
Fax: 516.328.3365
Spam
This was discussed in another thread... the poster was legitimate and trying to folks. Would be good if you went back and edited all threads you marked as spam.
Not Spam
