Installing a Minisplit Head Near a Stovepipe
![](https://secure.gravatar.com/avatar/f7cb174131f4b8d299ff0e3df9b44e6c?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Ft.png&r=g)
charles3
| Posted in Mechanicals on
Double wall stove pipe has a clearance to combustibles of 10″. How close to the stove pipe can a minisplit head safely be installed?
My guess is at 10 inches the plastic case of the mini would turn liquid and drip on the floor.
It seems to me that the heated air off a wood stove is likely to warm the air above the stove to over 130°that could soften the plastic for about 10 feet more or less.
To piggyback on Walta's comment . . . it seems less than ideal. If you aren't already committed to a wall-mounted head, maybe consider a floor unit. According to this article, research has found that floor-mounted units perform better for heating than indoor units that are mounted high on a wall (never mind the added complication of heat from a stovepipe).
Kiley, I don't understand how a unit on the floor near the stove is safer than a unit on the wall near the stovepipe.
Related question: Are there some brands and models that are more tolerant of heat than others?
In case anybody is interested, I asked this question of a guy who is National Fireplace Institute certified, and he said 10" is no problem. I guess the heat pump makes the plastic about as warm as the stovepipe would.
I have a black microwave about 18" from the stove pipe, the plastic on the door barely gets warm.
