Minisplit for a new garage in Zone 6B?
![](https://secure.gravatar.com/avatar/f54ad72db9fd047c97aa53bab53ce5a8?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
Hello,
I am building a detached garage in zone 6B. Zip 54016. I’m leaning toward a natural gas unit heater , because I assumed that my climate would not permit a mini split heat pump only. Am I wrong?
Jeff,
Mitsubishi and Fujitsu make ductless minisplit units that perform well when outdoor temperatures drop to -15°F or even -20°F. For more information, see How To Buy a Ductless Minisplit.
If you're going to maintain the garage at a temp of 60F or higher a cold-climate mini-split will definitely do it. But if you only intend to heat the space intermittently for periods of a few hours when you need to work there it's not the right solution.
