Minimum Thickness of Timber HP on Exterior of 2×6 Walls
![](https://secure.gravatar.com/avatar/b5e4a1b47fd0b0676057cb4c832a94f9?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fd.png&r=g)
Hey There, Fellow Tradespeople!
I’m planning a wall system for a renovation project that will likely be (from inside out), 1/2” drywall, Intello Plus Smart Vapor Retarder, 2×6 studs with dense packed cellulose (between the studs), 1/2” cdx pine sheathing, WRB over cdx, a 3.5” layer of Timber HP Timberboard, ( R-13), over the WRB, 3/4” strapping (rainscreen) over the Timberboard, and wood clapboards—(R-33 total with R-13 continuous).
Does anyone know if the old rule of thumb for minimum required R-value for 2×6 walls, applies to Timberboard HP (wood fiber board)? I’m re-reading Martin’s article (and table) that specifies for Climate Zone 6, a minimum R-7.5 for 2×4 walls and R-11.25 for 2×6 walls, but believe this article was for foam sheathed walls–not wood fiber board exterior sheathing.
What I’m hoping to find out, is if I can safely get away with a thinner layer of the Timber HP, to save money– like maybe the 2.5” thick (R-9) Timberboard, due to the robust inner vapor control layer, carefully detailed air tightness on the warm side, and “different than foam board” approach/ characteristics. Any takers on this one?
