Minimum separation between two air intakes (ERV and makeup air)
I’ve done some searching but haven’t found any details on required minimum separation of two air intakes, one for a continuously running ERV (~100-120 CFM) and the second for a range hood makeup air supply (350 CFM maximum, occasional use). It would be advantageous if I could locate the intakes in alternate truss bays (i.e., at 32-inch centers). Can anyone clarify requirements for me?
There’s plenty of verbiage for required distance beween an intake and an exhaust …
Thanks!
I'm not aware of any separation space required for two intakes. I think you can place them as you describe.
