Minimum output of Mitsubishi MXZ-2C20NAHZ2
![](https://secure.gravatar.com/avatar/67c752c7a057b254128acd57cdfde320?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fp.png&r=g)
Does anyone know the minimum output of the Mitsubishi MXZ-2C20NAHZ2 in heating at 47, 17 and 5 degrees? The Mitsubishi submittal states the unit has a capacity range of 7,400-25,500 at 47 degrees while the NEEP database states a minimum output of 11,400 at 47, 13,000 at 17 and 14,500 at 5 degrees. The NEEP numbers can’t be right? I’ve looked through Mitsubishi’s docs and can’t find the info. The discrepancies between the submittals and NEEP for the 20k, 24k, 30k and 36k H2i units are all similar. Thanks for the help.
