MHK1 Wireless T-Stat capabilities?
![](https://secure.gravatar.com/avatar/77a43d17d1ee99d4ddba20c0daeb8006?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fc.png&r=g)
I have three Mitsu ducted mini splits. I believe they are the “Mr Slim” type – they are each model number SEZ-KD**NA4 (G), with an outdoor unit MXZ-4C**NAHZ.
Each indoor unit is controlled with what I believe is an MHK1 Kit; there is a Redlink wireless receiver wired to the indoor unit control board. Each receiver wirelessly communicates with an MRCH1 thermostat.
Thanks to a previous post on here, all three MRCH1’s are communicating flawlessly with a Honeywell Redlink Gateway THM6000R7001.
1. Reading the user manual indicates the MHK1/MRCH1 setup has a dehumidify mode. I can’t find this in my setup. Does the dehumidify mode work with the indoor unit/outdoor unit setup I have, and I just need to change the setup on the MRCH1, or is dehumidify not an option on my equipment?
2. The Redlink Gateway came with a C7189R Remote Sensor. I can’t get it to connect to the MRCH1’s. Can anyone advise whether or not the C7189R is compatible with my system? If not, if you have a need for one, make me an offer…
