Manual J load calculation software
Does anyone know of a software application which can be used to run Manual J heating and cooling loads which actually uses up to date R values or wall and ceiling assemblies? Cool Calc does not allow any choice higher than R-38 for roofs and doesnt allow the user to enter his specific R values for their walls/ceilings. I know there are others out there, but would prefer some help from someone who has already identified the better ones available..
Thanks
Hot2000 is free, and works alright,. I would like to see the library's updated or find a proper download for one. But you can enter your own R values. Would anyone have a link for libraries?
I also found one from an American site where you actually draw the house in 3D but I forget it's name off the top of my head. It was also free, and I believe came from a DOE website. I didn't like the set up as much so I moved on from it.
BEOpt is from https://www.nrel.gov/buildings/beopt.html.
https://www.coolcalc.com/ is another option I have seen mentioned
I have not used either, I am hopeful homeowner just starting the build process
An overview of available software:
https://uwaterloo.ca/low-carbon-building-skills-resource/sites/ca.low-carbon-building-skills-resource/files/uploads/files/energy_modelling_software.pdf
Thanks John. Do you have any experience with any of them? Im hoping to find one which someone has already tried and is happy with.
Hi
I suggest to visit https://www.eds.tech. It will be beneficial.
For HVAC Home Auditor https://www.eds.tech/hvac-home-auditor
For HVAC Load Calculator https://www.eds.tech/hvac-load-calculator
Thanx
Hi
I suggest to visit https://www.eds.tech/hvac-consumer-tool/. It will be beneficial.
Thanx
