low voc tape for foam board seams in basement
![](https://secure.gravatar.com/avatar/8ab93b43da1cff6d080888d034629a07?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fr.png&r=g)
I’m finishing a basement room, adding 2″ Foamular boards to the inside surface of the exterior walls and will have 2×4 framing with sheetrock in front of the foam. I picked up some Zip System tape intending to use it to seal the seams between the boards. However, the two rolls of unused tape sitting in the room are creating a very strong odor and I’m concerned that that odor might never go away if I use it for this interior application.
Anyone have thoughts on this or recommendations on a different tape?
Thanks!
